mods on kfx400 to take a piped yfz
Old Sep 26, 2004 | 06:00 PM
BeastMan's Avatar
Default mods on kfx400 to take a piped yfz
what all do u have to do to a kfx400 to take a piped yfz in a drag?
I know pipe, cams. what else will i need or do i have to bore it? We weigh about the same.
Old Sep 26, 2004 | 10:58 PM
mojavecan's Avatar
a 449 big bore kit from denton racing(the same as doug gust on his z)
Old Sep 26, 2004 | 10:59 PM
Sandgod's Avatar
Yep a Yoshi kit.. A Trinity kit won't do it.. The Yoshi kit is stroked and that is the deciding factor.. My bro owns both..
Old Sep 26, 2004 | 11:00 PM
scrambler123's Avatar
the z in my sig takes them.
Old Sep 26, 2004 | 11:12 PM
Rimmer's Avatar
save yourself the grief, the dissapointment and a blown motor and just buy a YFZ!
Old Sep 26, 2004 | 11:14 PM
lmao rimmer whys that?
Old Sep 26, 2004 | 11:55 PM
BeastMan's Avatar
dang it i forgot i want to go alky.... with a bore, which would be best, if im going to bore i might as well go all out.
Old Sep 27, 2004 | 12:40 PM
MURDR's Avatar
When i get my engine back next monday i will let you know.[img]i/expressions/face-icon-small-smile.gif[/img]
Old Sep 27, 2004 | 01:53 PM
you do not need a big bore to beat piped 450's.
Old Sep 27, 2004 | 02:20 PM
maddog56's Avatar
You wont avoid anything, the yfz blows engines faster than most modded z's anyway.
You dont need a big bore, scrambler is right. A high comp piston, cams, pipe, filter, carb and a little head work should have you beating stock yfzs with ease and a few piped ones. If you tap the piston out a couple thousandths, you will be taking piped, filtered, and cam modded yfzs.
