gluey substance in tank
Old Oct 1, 2004 | 10:12 AM
honda450es4x4's Avatar
Default gluey substance in tank
I have a 1998 honda forman es and i was out riding the other day and it started to spit and sputter like it was out of gas so i turned it on reserve and it died. we pulled back home with my buddy atv and we looked in th tank and it was like liquid glue in the botom. it will run fo about 30 seconds then it will die like it is out of gas. So i went and picked up a new fuel filter and that didnt help. it still does the same thing. I even cleaned the tank and the line before i put the new filter in. Could that white junk got into my carb? or what else could it be.
Please help!
Old Oct 1, 2004 | 10:31 AM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
clean/inspect the carb to be sure
flush the tank and new gas
Old Oct 1, 2004 | 06:37 PM
do you think the jets are blocked... what do i all look for in the inspection
Old Oct 1, 2004 | 08:04 PM
Bing's Avatar
Super Quad Patrol
pull the carb
remove the bowl
be sure that you dont have that gunk clogging anything (jets, pilot jet, so on)
maybe before you do all that,,,,try loosening the overflow screw on the bottom of the carb bowl. If the carb is getting fuel,,,it will start to run out of the overflow tube.
Old Oct 2, 2004 | 02:43 AM
hondabuster's Avatar
I agree...pull the float bowl and check for gunk in there. If its in the float bowl, then its probably in the carb passages.
wrencher82
Sep 30, 2015 04:27 AM
wrencher82
Sep 28, 2015 10:02 PM
2many2ride
Sep 27, 2015 04:35 AM
wrencher82
Sep 24, 2015 03:39 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
