2001 Rubicon 500
Old Oct 3, 2004 | 10:00 PM
Beav33's Avatar
Default 2001 Rubicon 500
Hi folks, I'm getting ready to buy a Rubicon, however i have some lighting troubles, maybe some of you have experienced. Seems the large light on top will not light at all, and i forget if the lowbeams(lower lights-both) or the highbeams light either. Bike has only 100 miles on it, and has been garage kept for awhile. PS...... headlight switch was turned "on", like i said, both lower lights in one mode are ok(high beam i believe) but switch the hi-low swith and BOTH lights go out. Upper large large does not work at all. Any ideas??? Thanks!!
Old Oct 4, 2004 | 01:26 AM
hondabuster's Avatar
Youll probably need a wiring diagram, to get to the bottom of it. Id start with the switch ( high /low switch), and ohm check it. Look for disconnected wires while youre at it.
Old Oct 4, 2004 | 05:25 PM
BS400EX's Avatar
Try replacing the headlight bulbs. I had a Honda Recon that had a headlight burn out. I went to get new bulbs and I was unknowingly given the wrong ones. I installed them and the lows worked but the highs didn't. I took them back out and realized that they were the wrong bulbs.
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
35dodge
Sep 29, 2015 09:40 AM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
patrick.oc123
Sep 16, 2015 03:45 AM
patrick.oc123
Sep 15, 2015 02:45 PM
