Bypass run/stop switch?
Old Oct 6, 2004 | 05:28 PM
Nevermore98's Avatar
Default Bypass run/stop switch?
Hi all,
My son has a 50cc Kazuma that I'm can't get started now. It's getting fuel OK. I suspect a bad run/stop switch. What's the best way to test or even bypass this (temporarily) to see if it the problem? It's a 3 position switch. Run in the middle, stop in the right and left positions.
Old Oct 9, 2004 | 12:10 AM
RacewayATV's Avatar
Dear nevermore98:
I am an authorized Kazuma dealer and I see that you are having problems with your unit. I had a customer that had a similar problem. 1st if you bought the bike from a dealer they should be giving you a 6mo. warranty on the bike. If you did not I would suggest the C.D.I box is bad. That will stop you from getting a spark. I would ask you to see if you getting spark or not. If you are not getting spark I would call the dealer you bought the bike from and ask for a C.D.I box. That should fix your problem. If I can help you out in anyway you can email us at www.racewayatv.com Or call us at are toll free number 1-888-Race ATV, All The Best.
Old Oct 9, 2004 | 09:05 AM
newnick's Avatar
My sons Viper had a similar problem, the key switch was corroded. I took it apart and cleaned it, applied some dielectric grease, put it back together and sealed it.
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
alzgarvin
Sep 11, 2015 08:53 AM
MrTrashMan2U
Sep 9, 2015 11:11 AM
Jason An Stacy Jones
Utility ATVs
Sep 6, 2015 02:25 AM
toonces
Sep 5, 2015 01:14 PM
