WINCH PROGRAM
Old Oct 12, 2004 | 02:09 PM
GOODGUY's Avatar
Default WINCH PROGRAM
LOOKING FOR PROS AND CONS TO KAWSAKI'S WARN WINCH PROGRAM FOR $69
IM THINKING ABOUT INSTALLING IT MYSELF OVER THE WINTER.
IS THIS A DIFFICULT TASK
LOOKING FORWARD TO ALL YOUR OPIONS
THANKS
Old Oct 12, 2004 | 02:15 PM
cookerwon's Avatar
no its not hard to do, really pretty easy actually,took me about three hrs but that was because i'm picky ,i cut the battery cables to length so i didnt have alot of excess cable wraped around everything and also mounted my rocker switch to the bottom side of the diplay cover instead of the left handle bar where the dealer mounts them, i put mine where i did so it dosent get broke in a roll over. all in all it just takes some time removing the plastic to run wires and the three hrs i worked on mine i wasnt hard at it. the winch is definitly worth the money
Old Oct 12, 2004 | 02:17 PM
GOODGUY's Avatar
WOW DOES IT SHOW THAT I DEPEND ON SPELL CHECK
opinion
Old Oct 12, 2004 | 02:19 PM
GOODGUY's Avatar
APROX HOW MUCH IS THE BRACKET AND ROLLER?
Old Oct 12, 2004 | 02:21 PM
cookerwon's Avatar
the braket to mount the winch comes with the $69 and the roller fairlead bolts right to the mount and you can get one for 30 - 40
Old Oct 12, 2004 | 09:57 PM
tattooedbaldwhiteguy's Avatar
installing the winch is fairly simple, just take your time, keep wires and electrical connections away from heat and moving parts. follow the instructions and even call your local shop for advise from a tech. if needed. i have installed numerous winches on quads trouble free, and im no professional mechanic. just remember to spool the winch out ( all but last spool ) and pull it in with a light load the first time - i always park the quad on a slight hill, attatch hook to something stationary, then pull the machine up to it, that always does it.
Johnny Mac
Aug 15, 2019 03:13 PM
salixair
Nov 3, 2015 08:25 AM
cboler9
Sep 24, 2015 08:35 PM
ylomnstr
Sep 10, 2015 06:45 AM
chewy78
Sep 8, 2015 10:37 AM
