400 EX rear bearing problem.
Old Oct 13, 2004 | 07:56 PM
BS400EX's Avatar
Default 400 EX rear bearing problem.
I have a 400 EX and I need to replace the rear bearings but they are not coming out very easily. Does anyone have any suggestions on how to get them out?
Old Oct 13, 2004 | 08:38 PM
blue250r's Avatar
What isnt coming out ?
axel , or bearings from carrier ,how far have you got ??
Check out riva parts finder for drawings that should help.
Old Oct 13, 2004 | 08:43 PM
BS400EX's Avatar
The rear bearings inside of the axel carrier won't come out. I have the repair manual for the 400 EX. How would you pull them out if they are stuck?
Old Oct 13, 2004 | 10:00 PM
TractorPacker's Avatar
Do you have a balloon?
I just did mine, they are a pain. I welded a piece of steel to the smaller race of one bearing. You can then knock it out, squarely. When the first one is out, remove the inner pipe/spacer. That will expose the other bearing to knock it out.
Old Oct 13, 2004 | 10:49 PM
BS400EX's Avatar
Thanks guys I got it ... it just needed to be pryed a little more.
Old Oct 14, 2004 | 03:39 AM
cals400ex's Avatar
here is a tip:
place the whole carrier in an oven at 200-225 degrees. remove teh carrier and the bearings may just fall right out. if not, they shoudl come out after tapping on it with a piece of wood or something. if that still doesn't work, place them back in the oven for longer.
Ean
Dec 19, 2022 08:48 AM
STLyamwar
Jul 25, 2020 04:44 AM
akbrewcrew
Aug 9, 2015 10:54 PM
Peter_
Jul 18, 2015 07:06 AM
rcappie4
Jul 10, 2015 04:54 PM
