250R Pi$$ing me off
Old Oct 14, 2004 | 10:30 PM
1BAD250R's Avatar
Default 250R Pi$$ing me off
I need some advice. I literally just finished completely rebuilding my 1986 TRX250R yesterday. My signature below contains all of the aftermarket parts that I have on it that are brand new. This thing has 0 hours on it since rebuild. Well I went to tighten the motor mounts today and found a crack in the right side of my engine case which leaks oil. I love this thing to death but I am tired of dealing with this crap. I go to college and it is hard enough to find time to ride let alone time to turn wrenches on this thing. I'm not trying to sound like a whiner but do you know how frustrating it is to invest $3,000 and months of work into a project and then find a huge flaw? I would love nothing more than to keep it but a new YFZ is sounding pretty good right now.
Old Oct 15, 2004 | 02:47 AM
2fun's Avatar
Definately sorry to hear that.
Who was responsible for cracking the case?
Definately is going to have to be fixed, and depending on the severity of the crack, may need to be replaced altogether! I believe a new one runs close to 300 bucks?
Old Oct 15, 2004 | 02:54 AM
ubertrailblazer01's Avatar
lol...my friend cracked his piston on his brand-new 04 TLE pred...had to fix it up at the dealers...then again he was pretty much dragging by the first day
Old Oct 15, 2004 | 03:44 PM
Bubba297's Avatar
Too much silicone or Hondabond,etc in the bolt holes will cause the end of the hole to split when they are tightened down. I've seen it happen several times. The cases are thin and dont give much. Dont know if this is what happened to yours or not, but thought I would throw that in.
Old Oct 15, 2004 | 05:35 PM
bansheeesmoker's Avatar
slap some jb weld on it see if it works till you can afford to fix it, check the oil often though.
Old Oct 15, 2004 | 06:24 PM
warmdye's Avatar
yep JB it
Old Oct 15, 2004 | 08:00 PM
1BAD250R's Avatar
I've had some time too cool down, so I'll probably just fix it. I'm gonna XC race this quad and I want to make it bullet proof so I will probably just replace the case. Thanks for the replys.
Old Oct 15, 2004 | 10:33 PM
Yeah. Happens to all of us. lol
Old Oct 16, 2004 | 05:41 PM
86LT250RFatty's Avatar
LOL. i had the same Problem. I just got done re-building my 86 LT250R and i found out my right case was twisted slightly and wouldent hold oil. Good luck with the motor tho.
Old Dec 14, 2004 | 03:56 PM
1BAD250R's Avatar
Just to fill you guys in on what happened, I went above and beyond. I ordered two BRAND NEW right snd left case halves from Service Honda that should be getting here any day. I'm also going to install a new top end with EBC clutches with kevlar and heavy duty springs. Also got all new oil seals and gaskets, of course. The engine had almost no time on it anyway but hey, if you are gonna do somethin'....do it right!
