HP Gain from Exhaust?
Old Oct 16, 2004 | 01:17 AM
kawiyowee's Avatar
Default HP Gain from Exhaust?
My dealer has access to a dynomometer and tells me he has never seen an increase in hp from an after market exhaust pipe. Don't waste your money he tells me.
I have seen statements on here from credible members that say HMF and Penland definitely do make a significant horsepower contribution.
Does anyone have dyno or timed run info on exhaust systems?
Are they worth the cost regarding durability?
Old Oct 16, 2004 | 01:52 AM
mucky's Avatar
I gained almost 3 hp changing my exhaust
you do have to rejet it
that guy must be nuts
yoshimura dyno charts
Old Oct 16, 2004 | 08:22 PM
enFORCER's Avatar
Your Dealer sounds like a bad business man and a Fool.....
Old Oct 17, 2004 | 01:35 AM
kawiyowee's Avatar
mucky: Do you happen to know if there is a Yoshi pipe off your chart that would work for a Prairie atv?
(from one ex-desert rat to another.....I grew up in Phoenix and still dig it)
Old Oct 17, 2004 | 01:31 PM
OuterLimit's Avatar
I think is depends on what ATV you start with, and what brand of aftermarket exhaust you use, because some combinations are certainly better than others. I know that the Raptor and the DS650 both respond by leaps and bounds to an exhaust change, although with the DS650 it seems to be more a matter of removing the restrictive stock exhaust end cap than it is anything the specific aftermarket exhaust system is doing. The V-Force responsds well to some aftermarket exhaust, and not others. Diamond G Racing did dyno testing on half a dozen different aftermarket exhaust for a V-Force, and some produced good gains, but one brand ended up making less horsepower than stock (I could never really pin down Diamond G about which brand it was, due to fear of liability, I believe). So I would suspect your P650 would respond more to one brand of exhaust than to another, just like the V-Force. I would go with a proven brand with legitimate endorsement behind it, like the Penland Series exhaust by HMF, if it were me.
And I think your dealer is wrong to make a blanket statement that NO aftermarket exhaust can make a difference in horsepower, that is just wrong, and shows his inexperience on this subject.
OL
Old Oct 17, 2004 | 01:41 PM
LilMikey's Avatar
Enforcer your dealer must be a goof!!! Every bike I have ever put a pipe & kit on has gained hp & torque, dyno proven True maybe not alot but did gain
Old Oct 17, 2004 | 03:33 PM
enFORCER's Avatar
Hey Lilmikey, grow a brain....... I quoted Kawiyowee and I posted under the quote.... If you look at my pics you will see I run after market pipes on both of my bikes..... I made NO mention of my dealer you fool, learn how to read before you post....
Old Oct 17, 2004 | 08:33 PM
Marylandatv's Avatar
Im getting a noticable gain in HP on my Prairie 700 with the HMF Penland. I also like the Torque insert or (TRM) That comes with the set-up. I think in some cases with slip-on Mufflers more noise is made then Horse Power, If your thinking about an aftermarket exhaust get a Full System. ~coop
www.MarylandATV.com
785~V-Force
Prairie~700
Old Oct 17, 2004 | 11:11 PM
tafil's Avatar
A buddy of mine has a grizz. I spanked his butt with my p-700. And he went out and got a T-4 slip on,dyno jet kit, and a k&n, and now it's even. So a slip on does make a big diff.
Old Oct 18, 2004 | 12:03 AM
LilMikey's Avatar
Sorry for making a mistake, Last I knew there was only one person that was perfect in this WORLD and he was cruesified.
