eton 90 bottom end problem?
Old Oct 16, 2004 | 09:23 AM
billyyorkville's Avatar
Default eton 90 bottom end problem?
Hi Guys- Was about to do a top end on our viper90 when I noticed what seemed to be a lot of side-play in the connecting rod. When holding the the piston at tdc, the connecting rod will wiggle 3/8" side to side, Is this play normal? Thanks in advance for your time.
Old Oct 17, 2004 | 04:42 AM
dj250r's Avatar
do you have a lot of hours on it ? and that dose seem a bit excesive
Dwayne
Old Oct 17, 2004 | 02:14 PM
Doctorturbo's Avatar
GOT BOOST!
These things have roller bearings in them, so they do have a ton on play in them. How much is too much? I can't say, I don't have the spec's for the motor your talking about. If you can find a shop that has a new crank acc. in stock then you can compair the two.
Ramman1
Jun 16, 2016 09:07 PM
clsharky
Jul 13, 2015 02:07 PM
rcappie4
Jul 10, 2015 04:54 PM
D-Hagz
Jul 4, 2015 02:19 AM
