Tire/Wheel Balancing
Old Oct 18, 2004 | 11:58 PM
elkbow's Avatar
Default Tire/Wheel Balancing
I posted in one of my other threads, but most of you probably won't see it....
Have any of you taken your ATV Tires and Wheels to a regular automotive tire place to get balanced. I've always taken them to the motorcycle shop, but I can't see why I regular automotive place couldn't balance the setup and they usually have better equipment than most motorcycle/atv stores?
dave
Old Oct 19, 2004 | 03:01 AM
Snowwolfe's Avatar
If you ever balanced a motorcycle tire mounted on a rim it really isnt that difficult. You just need an axle to rotate the tire on mounted to a strudy, level surface and the weights. Pm me if you like to know more or do a web search. The procedure is very easy and very effective.
Old Oct 19, 2004 | 08:03 AM
elkbow's Avatar
Motorcycles are easy because they have a small shaft, I can do the same with my bicycle tires with a shaft and a couple of small bearnings mounted on a stand, but an ATV is different due to the large hub...
jgiljr
Aug 21, 2015 06:15 AM
gixxer600
Aug 16, 2000 08:23 AM
gixxer600
Aug 15, 2000 09:47 AM
Rob4092
Jul 13, 2000 12:24 AM
2k400ex
Jun 24, 2000 11:32 PM
