Tire size
Old Oct 19, 2004 | 07:52 AM
Oldtimer's Avatar
Default Tire size
I have a 05 Rincon. Most of the guys around here switch to a bigger tire, generally two sizes larger (25" to 27"). I feel it raises your center of gravity which decreases your stability, raises your gearing which lowers your pulling power and puts more of a strain on your drive train, all for up to an inch more ground clearance. What is the consensus of opinion on this board? Thanks.
Old Oct 19, 2004 | 11:57 AM
BS400EX's Avatar
Default Tire size
They will raise your center of gravity but if you get wider tires as well they will help give you back some traction for low-end power. If you are doing serious mud-running, then bigger tires are a must. They are also nice to have when climbing over tall obstacles. The Rincon is more of a sport-oriented quad so I don't know how big I would go because I heard that the transmission on them is goofy (ackward shift points, seems to have lack of power, etc.). I have never been to Texas so I am not sure if there are many hills and such that you would have a problem with keeping your stability from larger tires. If you are doing any pulling with the Rincon I would say that you have the wrong quad anyway, and I am sure that most would agree with me, because it already has a lack of low-end power. Go with ITP 589's or something that is taller, wider, and nearly the same weight as stock. This will help prevent strain on the drive-train. Also a jet kit and a K&N air filter ($50 each) would properly tune the engine and let it breathe better, giving your Rincon more power to turn the tires. If you want ground clearance without larger tires go with a lift-kit for under $100. Note this will also raise the center of gravity on you Rincon. I hope that I helped.
Bratman2
Aug 6, 2022 01:42 AM
Hankey Pankey
May 1, 2018 01:33 PM
Hankey Pankey
Aug 17, 2015 05:01 PM
2007 Grizzley 450
Aug 13, 2015 06:33 PM
rcappie4
Jul 18, 2015 07:51 AM
