tank dent
Old Oct 22, 2004 | 10:49 PM
devocorky's Avatar
Default tank dent
I just purchased a 300 fourtrax and it has a good dent in the side of the tank. ( not from me ) Does anyone have any suggestions as to how to remove it or have it repared??
Old Oct 23, 2004 | 08:59 AM
powerslider's Avatar
Default tank dent
Try a wooden broom handle type dowl and work it out through the filler neck. I done this once on a Honda motorcycle and it worked well....
Old Oct 23, 2004 | 06:33 PM
TractorPacker's Avatar
Do you have a balloon?
Default tank dent
I have never tried this but........ Fill it full of water and put the cap on it with the vent closed off. Throw it in the freezer.
I doubt it works but that is folk lore I have heard.
Old Oct 23, 2004 | 10:13 PM
alleycat's Avatar
Default tank dent
I've seen this work on car fenders you might want to try. If you have a small plunger and can get a seal around the dent, when you pull the plunger out it may have enough suction to pull the dent out. I know car fenders are a little thinner and lighter but won't hurt to try.
Old Oct 23, 2004 | 10:57 PM
devocorky's Avatar
Default tank dent
I thought about the plunger trick but i suspect the metal on the tank is too thick for this. As far as the water fill idea i'll pass on that one. I think i will try the dowell through the fill hole. Thanks.
wrencher82
Sep 30, 2015 04:27 AM
wrencher82
Sep 28, 2015 10:02 PM
2many2ride
Sep 27, 2015 04:35 AM
wrencher82
Sep 24, 2015 03:39 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
