tank dent
I have never tried this but........ Fill it full of water and put the cap on it with the vent closed off. Throw it in the freezer.
I doubt it works but that is folk lore I have heard.
I've seen this work on car fenders you might want to try. If you have a small plunger and can get a seal around the dent, when you pull the plunger out it may have enough suction to pull the dent out. I know car fenders are a little thinner and lighter but won't hurt to try.
I thought about the plunger trick but i suspect the metal on the tank is too thick for this. As far as the water fill idea i'll pass on that one. I think i will try the dowell through the fill hole. Thanks.
