Going back to Dino!
Old Oct 26, 2004 | 07:12 PM
Ozark38's Avatar
Default Going back to Dino!
A few months ago I switched to Mobil 1 MX4T motor oil (full synthetic) and the last few times I had it out I noticed my clutch slipping. At first it only did it when speed shifting while drag racing but it has gotten worse. I'm thinking its because of the oil cause it never did this when I was running the dino. It possibly could be a worn clutch but the bike isn't even a year old and I'm not really that hard on it except for a little drag racing now and then. I have some mods on it but nothing major (stock bore and compression) but it does run good.
I'm going to try dino again and see if it helps. Have any of you guys had problems with your clutch running full synthetic motor oil? Or is it typical for a clutch to go this soon? What say you, Man?..........[img]i/expressions/face-icon-small-smile.gif[/img]
Old Oct 26, 2004 | 07:14 PM
maddog56's Avatar
Not sure what the oil specs are, but did you make sure it didnt have any friction modifiers in it?
Old Oct 26, 2004 | 07:19 PM
Ozark38's Avatar
Not sure but MX4T is Mobil 1s 4 stroke motorcycle oil so you would think I shouldn't have problems with the clutch but ?
Old Oct 26, 2004 | 07:24 PM
maddog56's Avatar
ok, didnt know the specs on the oil so I figured I'd ask. Dont know what to tell you if you were having clutch slippage then. Maybe your plates are worn out...
Old Oct 26, 2004 | 08:27 PM
blood's Avatar
Since the tranny uses the same oil as the motor I was told by many mechanics to use a synthetic "blend" if you want synthetic. And the folks at Wiesco recomend a synthetic blend after break in.
Old Oct 26, 2004 | 10:32 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
I presume that MX4T is motorcycle oil, not car oil???
I run Honda HP4 synth blend in all my manual clutch bikes (but not autoclutch bikes).
Reactant
Mar 30, 2022 02:08 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
Countrygirl1976
Jul 13, 2015 10:08 AM
rcappie4
Jul 10, 2015 04:54 PM
Coryco
Jul 6, 2015 07:30 PM
