how to peel out?
Old Oct 26, 2004 | 10:55 PM
Cab00se's Avatar
Default how to peel out?
i was wondering how u guys could tell me how u doit
Old Oct 26, 2004 | 10:59 PM
blastakid200's Avatar
on the dirt i just put it into second gear rev it nice and high and then pop the clutch and you peel out sprayin sand lol.
2phast4u2catch's Avatar
yea wat he said^^
Old Oct 26, 2004 | 11:01 PM
FdaDOT200's Avatar
hold the front break real hard and put it in 1st and pop the clutch......lol
Old Oct 26, 2004 | 11:04 PM
i did that b4 and i did a burn out as soon as i let out the clutch my front brakes blew and i fliped it
Old Oct 26, 2004 | 11:12 PM
Yea that sucks, i dont use the front brakes mostly because there terrible and dont work well[img]i/expressions/face-icon-small-smile.gif[/img]
Old Oct 27, 2004 | 02:35 AM
Jibrille's Avatar
When I had semi-bald tires, with like 40% tread left I could put all my weight up front over the gas tank and punch it and it would spin out on the pavement, on dirt all you need to do is punch it, as long as your quad has the power.
Old Oct 27, 2004 | 02:55 AM
longbox's Avatar
Hey Cab, are you talking about the wolverine you have in your sig? If it is a wolverine, it's full time 4wd(unless you've got the unlocker kit) and it will be very hard if not impossible to do. Since the front wheels are connected to the rears, if you hold the fronts and nail it, you're actually holding the rears also, which doesn't help too much. I suppose if you were on loose dirt, or sand you could peel out briefly if your tires don't bite, but smoke shows are definately out of the question.
If you do have the unlocker kit, then in 2wd you can hold the front brakes and nail it and probably get a peel out going how these guys are telling you to. Just realize that depending upon traction and tire size, you will not be able to peel out as well as the sport quads everyone is talking about. I'm not knocking your quad, just pointing out that these other examples all have manual clutches(easier to get it started) and different power curves/more power.
Hope this helps.
Good Luck!!
Old Oct 27, 2004 | 10:29 AM
potentpete's Avatar
who's buying the tires?
Old Oct 27, 2004 | 10:40 AM
BlackRaptor's Avatar
On tar put it in first gear rev it up all the way to the top of the power band lean back and dump the clutch. [img]i/expressions/face-icon-small-shocked.gif[/img] [img]i/expressions/face-icon-small-wink.gif[/img] [img]i/expressions/face-icon-small-confused.gif[/img]
tbsleeper
Jan 16, 2005 12:59 AM
dmger14
Oct 14, 2004 11:05 PM
ChiefUllig
May 27, 2003 11:14 AM
Stewart
May 1, 2002 11:22 PM
