350 Raptor and 350 Warrior parts
Old Oct 27, 2004 | 02:22 AM
AzRaPt0rS's Avatar
Default 350 Raptor and 350 Warrior parts
Is there a confirmed list of what parts will fit a 350 Raptor form a Warrior or any other quads? So far I know that the air filters will, but what about complete exhaust, torque stuffer, front bumpers, and skid plates? Thanks
Old Oct 27, 2004 | 02:32 AM
2FAST4URASS's Avatar
i sure wish i knew lol
Old Oct 27, 2004 | 11:59 PM
FoxSpirits's Avatar
correct me if im wrong but i beleive they replaced the frame of the warrior but the motor is still stock, which theoritically means all motor parts should be interchangable.... dont hold me to that though.
Old Nov 12, 2004 | 12:37 PM
ande12019's Avatar
Alba has the Raptor 350 and warrior in the same parts category, but I ordered a pipe and it was different from the warrior's. I also asked them if the 400 kit for the warrior would fit on the 350 raptor and they said no because it was a different engine. I thought it was pretty much the same. They should give the raptor 350 it's own category as well since most parts really won't fit.
Old Nov 12, 2004 | 06:24 PM
Leroy252's Avatar
The frames, motor and carbs are the same but exhaust is different. You should be able to use the same skidplates and bumpers.
Old Nov 12, 2004 | 06:31 PM
AzRaPt0rS's Avatar
I'm pretty sure the carb is different, I think the frame also has some differences to it.
Old Nov 12, 2004 | 06:40 PM
VelociRaptor350's Avatar
Yeah that pissed me off about Alba, The lump the 2 bikes together and then expect you to know the stuff dosn't fit. I wanted to order the yoshi pipe but of course it dosn't fit. HMF noticed this and actually made a slip on for raptors, you would think alba would put a little notice or something on their site like hmf.
Old Nov 12, 2004 | 07:03 PM
yea the carbs are diffrent the warrior has a mikuni btm 36 mm carb the raptor has a~~~~~36 mm BSR which is a bigger carb and the frames are diff some of it is the same but if you put them side by side you will see the diffrences but as fas as the motor internaly its the same and the raptor is 27 pounds lighter so they say
Old Nov 13, 2004 | 12:03 AM
The head pipe is diffrent, so no slip on's will fit, some shifters have clearence issues, and the list goes on.
Firefighter400
Oct 8, 2022 06:38 PM
Reactant
Mar 30, 2022 02:08 AM
black_thunder
Jul 22, 2015 06:01 PM
Reactant
Jul 16, 2015 10:29 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
