Compression check on a 250R
Old Sep 1, 2000 | 11:42 PM
Duner97's Avatar
I just did one after I discovered a leaking base gasket. After $400 for a stator and CDI its still not getting spark. What kind of compression should I be betting?
Old Sep 2, 2000 | 12:53 AM
retro's Avatar
About 150 or so is normal.
ERIC
Old Sep 2, 2000 | 02:56 AM
Duner97's Avatar
Well I'm getting about 90. think a new gasket will do the trick? And do you think that this can cause it not to get any spark when kicking it over, but it started when I pull started it. (?)
Old Sep 2, 2000 | 07:04 PM
HRC4EVER's Avatar
i think 150 is high.but 90 is defenitely time for new piston and rings-if it started you got spark.
Old Sep 2, 2000 | 10:52 PM
Dill's Avatar
150 is about stock...90 lbs is either a really leaky head gasket, or time for new pistons and rings..if you put a few drops of oil into the cylinder, then run the compression test, and the results go up, you need new rings/piston..
Old Sep 2, 2000 | 11:06 PM
Duner97's Avatar
Couldn't it be the base gasket causing low compression since it's leaking?
Old Sep 3, 2000 | 12:13 AM
Dill's Avatar
no, when the motor is creating compression, the ports are closed
slowgsxr97
Mar 18, 2022 03:40 AM
manuelrivera
Aug 8, 2015 04:34 PM
NatePerz
Jul 27, 2015 03:27 AM
ghost civic
Jul 19, 2015 10:13 AM
CRamshaw777
Jul 18, 2015 05:46 PM
