Compression check on a 250R
150 is about stock...90 lbs is either a really leaky head gasket, or time for new pistons and rings..if you put a few drops of oil into the cylinder, then run the compression test, and the results go up, you need new rings/piston..
CRamshaw777
Jul 18, 2015 05:46 PM
