Need help with Engine Brake Actuator
Old Oct 31, 2004 | 02:55 PM
LuvDaMud's Avatar
Default Need help with Engine Brake Actuator
I've had some problems with my EB Actuator lately . Now it doesn't work at all. I took it appart and tested the motor and gear assembly ; it works perfectly. The problem is in the 'dimmer like' resistor in the actuator that tells the control the position of the actuator handle. I wonder if I can just replace that resistor or do I have to replace the whole actuator. Everything else in the actuator is perfect. Seems a waste of money to have to replace the whole thing. Would appreciate some feedback on this. Thanks.
____________________________________
P650 red 2003
Holeshot Module
Dalton Springs
ITP Cast Alum Rims
26in Bear Claws
Snow Trax for deep snow
Full Equiped
Old Oct 31, 2004 | 03:59 PM
Customfabandweld's Avatar
Mine doesn't work all the time, and I can't figure it out. I'm about to take mine off, anyway, and use a V-force clutch cover.
Old Oct 31, 2004 | 04:52 PM
LuvDaMud's Avatar
But if you do that , you will contiuously have that blinking 2wd - 4wd on your display. It's annoying because you never know if you are in 4wd unless you look at the switch on the right handle.
Old Nov 1, 2004 | 12:16 PM
Uinthas's Avatar
do you have the actulator arm in the correct position?? it wont work unless it is
Old Nov 1, 2004 | 03:30 PM
trailblazermudrunner's Avatar
hey just replace it it may be a lot of money but hey it saves in time and the anoyin s*** of takein it out and putin it back in
Old Nov 1, 2004 | 05:38 PM
Nightryder888's Avatar
diamond g racing makes a bypass module for it so the lights won't blink. mine did the same thing and i couldn't find a replacement sensor, i had to buy a new one for $234
Old Nov 1, 2004 | 10:14 PM
LuvDaMud's Avatar
I checked today at the dealer , it was $425 Can. They're nuts if they think I'll pay that for an actuator!!
I can easyly deal with the side effects of no K-EBC on my machine for that price.
I'm familliar with electronic components ; I'll try to find a replacement for this sensor. I'll let you know what I find.
Pretty sure it's a lot less than $425.
Old Nov 2, 2004 | 12:52 AM
kawiyowee's Avatar
I hope you find a solution that enables you to retain the kebc. That kebc has saved my behind in the mountains many times. Much better than braking imo.
Old Jan 8, 2005 | 01:55 PM
caverdave's Avatar
Hi!
I'm having the same problem with the actuator. Just wondering if you ever found a source for the variable resistor?
Caverdave
Old Jan 10, 2005 | 09:05 PM
LuvDaMud's Avatar
I have not!! I got tired of searching for a resistor to match it and I'm just living with it as is.
