Need help with Engine Brake Actuator
Old Jan 10, 2005 | 09:44 PM
tuffEnuf's Avatar
Default Need help with Engine Brake Actuator
Try your local Electronics Shop. Usually resistors has what Ohm/voltage written on them. Resistor could possibly be de-soldiered and another soldiered in? Worth a try & if it works will be alot cheaper.[img]i/expressions/face-icon-small-cool.gif[/img]
TuffEnuff
Old Jan 12, 2005 | 08:10 PM
LuvDaMud's Avatar
Trust me , I'm a electronics tech. This ain't no run of the mill Radio-Shack resitance , this is a variable resistor that varies depending on where the actuator arm is located. This tells the computer to give more engine brake or less depending on the speed your going. This resistor was designed for this aplication.
Johnclay
Utility ATVs
Jul 19, 2015 10:00 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
clsharky
Jul 13, 2015 02:07 PM
timster911
Jul 13, 2015 01:57 PM
MNatv89
Jul 7, 2015 11:36 AM
