warrior dont crank
Old Nov 1, 2004 | 09:08 AM
titty's Avatar
Default warrior dont crank
87 warrior, battery is charged, i go to start it and the starting circuit cut off relay clicks and thats all i get wats the problem
Old Nov 1, 2004 | 02:40 PM
hondabuster's Avatar
The voltage is dropping too far. Check for corrosion on the battery contacts. If everything is clean and tight, then have the battery, load tested. Any good auto parts store will do that for free. If you have a voltmeter, hook it up to the battery terminals, before starting, and watch the voltage while cranking. It shouldnt drop below 10 volts while cranking.
Old Nov 1, 2004 | 03:38 PM
Bosch's Avatar
Make sure your ground cable is clean & tight on both ends.
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Jackg17
Sep 26, 2015 09:30 PM
Bernhard
Sep 25, 2015 12:45 PM
