More bottom end! Scrambler 500 4x4
Old Nov 1, 2004 | 10:33 PM
Petroman's Avatar
Default More bottom end! Scrambler 500 4x4
Whats the best and easist way to get more low end torque / power? Could I put a one or two tooth smaller sprocket on the drive without adverse 4x4 effects? Or should I change the clutch setup? Or do both? I don't need a 60 mph 4x4. 50 or so would be fine. Thanks!
Old Nov 1, 2004 | 11:42 PM
Polaris500HO4x4's Avatar
try going with a plain spring in your primary... ask BBS he can send you in the right direction
Old Nov 1, 2004 | 11:57 PM
scramblerXrated's Avatar
i found a nice gain in throttle response and low end when i reset my secondary clutch from the 2-2 position to the 1-3 position.
X
Old Nov 1, 2004 | 11:58 PM
97RamSST's Avatar
Honstly, you're the first person I've ever heard complain about not having enough low end power in a Scrambler.
Old Nov 2, 2004 | 01:00 AM
BigBadScrambler's Avatar
MY clutch is setup for a higher engagement. ftwflh has a Dalton primary spring from Rick Ritter @ RCR that has the low engagement with faster shift out that he likes. The secondary on the 2-2 with a HPD violet secondary spring is awsome in the trails. Give Rick a call and have him set you up with a Dalton spring. A good pipe (HPD) or slip-on (White Bros) will help too.
Old Nov 2, 2004 | 01:03 AM
oh yeah,
definitely stay away from changing the gearing if you plan to keep your 4x4 setup.
you are pretty much limited to clutching, carb, intake and pipe mods. these mods in combinations , can wake your scrammy right up.
X
Old Nov 2, 2004 | 07:57 AM
ftwflh's Avatar
For me to get better botom end I got the best results from the White Bros muffler then with a clurch spring change I went with a Dalton black/white it is cose to the Polaris green.I have now went with a Polaris yellow for more rpms on the top and a low engagement.You can also try a heavier set of shift weights like a S58 or 10/58 this should get you to stay in low gear longer before it shifts out.
Old Nov 3, 2004 | 12:14 AM
mudmaster250's Avatar
i have a dalton black/orange if anyone would like to have it for lets say 10 bucks.
exmotocrosser
Sep 13, 2019 06:12 AM
badgerboy1
Sep 26, 2017 06:11 PM
Beeline08
Nov 11, 2016 04:00 PM
Matt123
Sep 29, 2015 01:29 AM
2many2ride
Sep 27, 2015 04:35 AM
