clutch feels like it is slipping
Old Nov 2, 2004 | 06:20 AM
tomkat510's Avatar
Default clutch feels like it is slipping
my clutch on the 350x feels like it catches high, like at the end of the clucth level when i release it, can anyone help me out [img]i/expressions/face-icon-small-confused.gif[/img]
Old Nov 2, 2004 | 10:08 AM
GlennJ's Avatar
Before you go tearing into the engine, adjust the cable. Better yet, replace the cable.
Old Nov 2, 2004 | 12:45 PM
MY86ATC350X's Avatar
yea bro my 350x does the same thing, im going to change my cable i think its getting stuck when i realease it, if it keeps occuring its proably the clutch.
Old Nov 2, 2004 | 03:03 PM
ThrashAndCrash's Avatar
To ask a question, Are you using REGULAR motor oil, or synthetic...... me and all my riding buddies have all found out the hard way, MOTORCYCLE OIL ONLY! made for wet clutches.
Old Nov 2, 2004 | 10:59 PM
yep i use atv oil, i use sometimes valvoline atv motor oil for wet clutches.
and on my trike the clutch is little harder to pull than my friends raptor.
Old Nov 3, 2004 | 03:30 AM
cool, good on the oil, Have you adjusted the cable to the point where when you pull the lever you have a little "freeplay" in it before it moves the clutch arm on the trans?
If you have freeplay in the cable and you are running good oil, and it still grabs late you are looking at getting new friction discs.
Old Nov 3, 2004 | 01:43 PM
i think everything is ok, but its age on that clutch, i thin kit needs replacing, ive adjusted everything. im going to buy a new cable to see if thats the prob. but i use regular atv motor oil for wet clutches. i thinks thats good right?
Old Nov 4, 2004 | 08:08 AM
mrtrikes's Avatar
If your clutch is on its way out it will slip more in the higher gears.
Old Nov 4, 2004 | 03:45 PM
Vinson581's Avatar
just bit the bullet and get a new clutch, my rm's clutch was slipping, and it turned out to be burnt, worn blued spacer plates( the silver discs) i wouldnt idle in gear which got really annoying, and that made it difficult to get in neutral. got me a new clutch, and wow what a difference, all the problems went away.
when installing the clutch, be sure to soak the components, in oil for at least 15 min before you install it, and then when you first start it ride the clutch a couple of times to ensure that everthing is seated properly..
581
ghost civic
Jan 15, 2020 07:43 AM
Cummins Driver
Sep 11, 2019 01:22 PM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
Reactant
Jul 27, 2015 07:45 PM
