need help on a-arm bushing replacement
Old Nov 7, 2004 | 02:26 PM
mean650's Avatar
Default need help on a-arm bushing replacement
hey i
i just bought another set of a-arms with out the rubber boot(grease),are they pressed on?can i re- use them or do i need to order new ones,their isn't a dealer in augusta any more.i have to have everything shipped.i removed the clip..what next please!thanks
Old Nov 7, 2004 | 02:32 PM
JMAC650's Avatar
Are you talking about the bushings or the ball joints? The bushings should just pull out in 2 pieces with the teel sleeve. As far as the ball joints just remove the clip and tap them out with a socket and hammer. Just make sure the socket is just a bit smaller than the ball joint. Also you are supposed to loctite the new ball joints back in with green loctite.
Old Nov 7, 2004 | 05:31 PM
mean650's Avatar
thanks jma,
the ball joints was what i needed the info on .i didnt know which way to knock them out.thanks.
Old Nov 7, 2004 | 05:47 PM
JMAC650's Avatar
Take the clip off and tap them out on the same side as the clip.
Old Nov 7, 2004 | 08:05 PM
mudnuri's Avatar
I just changed mine this morning. I used a press and a socket like JMAC said. First took the cir clip off.
The book says to use a template they provide to align the ball joint when it goes on the new arm. It has flat sides and needs to go in one way. I can't figure why, but I think it matters. If you need a copy of the template let me know and I will send you a copy that you can print.
You need a bigger socket to tap the ball joint back in.
Old Nov 7, 2004 | 09:09 PM
JMAC650's Avatar
The flat spots both face side to side instead of front to back. They are designed that way because the balljoint and the arm are supposed to be a little oblong for a tight fit. But I didn't notice any difference when I installed mine, but still did it the way it was explained in the manual.
Old Nov 7, 2004 | 09:18 PM
mudnuri's Avatar
Tourque specs for nuts on a arm are 46 ft. lbs.
Castle nut on ball joint- 37 ft. lbs.
Old Nov 8, 2004 | 10:15 AM
mean650's Avatar
thanks everyone,
i felt like a dumd a.. for asking that question, but i didn't know.i told my wife that all i needed to do was come on here for an hour and i would get all the info i needed.this site and people have helped me a lot throught the years so,THANKS to the best bunch of hardcore riders and engine builders i have ever dealt with!james
Old Nov 8, 2004 | 11:51 AM
JMAC650's Avatar
[img]i/expressions/face-icon-small-cool.gif[/img]
STLyamwar
Jul 25, 2020 04:44 AM
Nondem
Feb 22, 2020 12:20 PM
toonces
Jul 28, 2015 01:58 PM
mdrkcckv
Jul 22, 2015 09:10 AM
musselmark
Jul 17, 2015 02:40 PM
