p700/warn winch
Old Nov 8, 2004 | 02:02 PM
GOODGUY's Avatar
Default p700/warn winch
Well I have installed my winch and I am working on wiring it up. Could you please help me in deciding where to put the solenoid?
Right now I’m thinking about mounting it under the seat and use wire ties to strap it to the frame. The solenoid would face the ground. It seems as though there is enough room from the exhaust pipes and in my opinion I think this is the cleanest place for it. My concerns are that I can't drill into the frame so it will only be supported by the wire ties.
Do you think this will be a good spot and good method to mount it?
Any other tips on winches would be helpful..
Thanks
Old Nov 8, 2004 | 02:31 PM
cookerwon's Avatar
i mounted my solenoid to the left of my airbox and bolted it to the front fender. if you take the cover to get at your airbox there is enough room to the left of the airbox to mount the solenoid in there and it is the cleanest place i could find it worked really well.
Old Nov 8, 2004 | 02:41 PM
GOODGUY's Avatar
Do you have any pictures
Old Nov 8, 2004 | 02:49 PM
cookerwon's Avatar
no i dont have a digital
Old Nov 9, 2004 | 02:19 PM
moody835's Avatar
GOODGUY,
I mounted winch connector under the seat on frame cross tube , just under the battery using
1 1/4 clamps. Tightened clamps on cross tube then used the threaded part of the u bolts as studs
to mount the connector. I only used 2 of the 4 connector mounting holes but seems to hold nice and tight with locknuts. Mounting here also made easy to wire connector and stays fairly clean up nice and high.You can get these clamps at any hareware store, I think I saw them at walmart too.
I dont have a picture as im not very good with computers but will try to answer any questions
GOOD LUCK AND HAVE FUN
Johnny Mac
Aug 15, 2019 03:13 PM
salixair
Nov 3, 2015 08:25 AM
cboler9
Sep 24, 2015 08:35 PM
ylomnstr
Sep 10, 2015 06:45 AM
chewy78
Sep 8, 2015 10:37 AM
