BF winch
Old Nov 11, 2004 | 03:28 PM
Harw's Avatar
Default BF winch
Here is some info I learned from Warn. I had a guy asking about a 4.0 winch and mount for his BF. Warn said that you cannot use a 4.0 winch on one, that the batterie and alternator are not large enough to run one. You will be pushing it to use a 3.0 winch.
Old Nov 11, 2004 | 04:00 PM
2005BF750's Avatar
Default BF winch
man, I didn't even know they made a 4000lb quad winch. I use a 3000lb on my Brute Force with no trouble at all, they sure don't have very big batteries though.
Old Nov 11, 2004 | 04:07 PM
maddog56's Avatar
Default BF winch
4k lb winch is a new one on me. The 3k just came out in the last year anyway, let alone a 4k.
Old Nov 12, 2004 | 02:54 AM
travelor's Avatar
Default BF winch
I have been waiting for weeks for a warn winch mount. Also for snow plow brackets for b.f.
Old Nov 12, 2004 | 05:54 PM
piski's Avatar
Default BF winch
Yup, there's a 4k lb. warn winch ....and yea...they recommend something like 600 CCA rated battery to run it. I just went thru trying to decide on a 3K or a 4K for my Argo.
Jeff
Old Nov 13, 2004 | 08:50 AM
jpsdiving's Avatar
Default BF winch
Do the research: I have ordered from these people(Click here: e-Winches.com - Home Page ) and they are very prompt in shipping.
Warn 4.0ci ATV Winch
The 4.0ci winch includes a hand-held remote control, contactor, roller fairlead, remote socket, 6 gauge wiring, hook with safety latch and hook strap.
4.0ci ATV Winch
Utility vehicles do so much work they deserve their own winch: the new WARN 4.0ci. It's a first cousin to the popular new generation WARN ATV winches that have impressed everyone from riders to writers.
The 4.0ci's bruising power comes from a 1.5hp high-torque motor. It pulls 55' of wire rope with enough power to tackle everything from self recovery to moving downed trees. This utility winch also features the Express InstallTM wiring system and a specially designed contactor pack. All in all, the WARN 4.0ci makes utility vehicles even more indispensable.
Part number: PN 66000
Rated line pull: 4000 lbs. single-line
Motor: 12C DC, 1.5hp permanent magnet
Controls: Remote Control, 10' lead Handlebar mounted Mini-rocker switch
Gear train: 3-Stage Planetary
Gear ratio: 136:1
Lubrication: Aeroshell #17
Clutch (freespooling): Cam Activated
Brake: Automatic Mechanical.
Drum diameter/Length: 2.0"/4.7"
Weight: 21 lbs.
Wire rope: 55', 7/32" diameter
Fairlead: Roller
Recommended Battery: 12 Amp/hour minimum for winching
Battery leads: 6 gauge
Duty Cycle: Intermittent
Finish: Argent Gray Powder Coat
Warranty: Limited Lifetime
Winch Dimensions: 14.69" L x 4.51" D x 4.65" H
Mounting Bolt Pattern: 3.00" x 6.66"
Old Nov 13, 2004 | 09:43 AM
Jeffro31's Avatar
Default BF winch
just use a 2000 lb or a 2500lb and a ****** block if you need 4000lb pull.
Old Nov 13, 2004 | 05:16 PM
4xZuk's Avatar
Default BF winch
J.C.! What would you ~really~ need a 4000# winch for-on an ATV? Are you planning on repo'ing 3/4 ton trucks? 2k-3k ought to be PLENTY. If not, use a ****** block. Don't fall into the "he who has the biggest ***** "nuts" the most" trap!------Damn! Oh, and if you're wondering (or give a f--k) why a Suz. dude is posting here: I raced Kawi's and still LOVE 'em!
Old Nov 13, 2004 | 05:56 PM
jpsdiving's Avatar
Default BF winch
No offense, but anyone is welcome here[img]i/expressions/face-icon-small-smile.gif[/img] We all ride for the same purpose, like mud, mud, and more mud, right...... All the brands are ok these days, except when you come to trucks of course[img]i/expressions/face-icon-small-wink.gif[/img] As for winches, hey whatever a guy wants to put on his rig, all the power to them.
By the way if I am stuck up too my arsh in mud, I do not have time nor the patience to be hooking up ****** blocks[img]i/expressions/face-icon-small-smile.gif[/img]
Old Nov 13, 2004 | 06:14 PM
piski's Avatar
Default BF winch
jpsdiving.......
I wonder why the specs you have call for a 12amp/hour min battery for winching for the 4000ci, when on warn's site it calls for a 500 CCA min. ??? The 12 Amp/hour is what they recommend for a 3000ci. I just wonder why that site would say one thing and on warn's site...it says another ? BTW I went with the 3000ci for the argo and just LOVE it...
Jeff
