starter problems with 300ex
Old Nov 12, 2004 | 07:24 PM
highflyinHonda's Avatar
Default starter problems with 300ex
I have power to the starter and it spins. The gears seem to fit up to one another, but when i go to start it up, i get either a clunking noise from the case, or u hear the starter wind up and then clunk in.
all the gears seem to mesh properly but i cant figure out why their is this noise...
Old Nov 12, 2004 | 09:45 PM
manual's Avatar
When you try to start it up does it turn over once and quit? If so it sounds like your starter gear is getting jammed up and not spinning the flywheel over proprely.
Old Nov 12, 2004 | 10:23 PM
WISTECH's Avatar
Your one way bearing has failed. There is a little band spring in them that break . It makes starting hit or miss. I think I might have a low mileage one at home Ill sell ya cheap.
Old Nov 13, 2004 | 02:32 PM
OK thanks for your help, can u tell me the best way to get at this bearing.
Old Nov 13, 2004 | 06:27 PM
WISTECH's Avatar
The one way bearing is right under the flywheel. You have to pull the left side cover to get at it. I have been able to get the flywheel off with 3 jaw pullers but you could go to a shop and have them pop it off for you.
Old Nov 20, 2004 | 02:42 PM
Well i read that u could get it off by using an impact wrench and a bolt and the bolt broke and is now stuck in side the flywheel...how screwed am i?
any suggestions would be apreciated
thanks
Old Nov 20, 2004 | 09:33 PM
Ok, nevermind i got the sucker out.
Old Dec 1, 2004 | 09:02 PM
I read that the clip breaks off, and that you can put an ring in place of it...is this true?
I got the flywheel off, how do i get the one way bearing off of this...?
thanks
Old Dec 4, 2004 | 02:49 PM
I got to the one way clutch off, but there is a wire type thing holding the bearings in place, it is however loose fitting...i dont see much wear, but if i manually turn the one way clutch against the gear, it will slip occasionally. What part do i need or can i fix this... The part one shop said i needed was about $150
Thanks....
Old Dec 4, 2004 | 04:10 PM
WISTECH's Avatar
Highflying check your PM
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Nov 15, 2019 09:59 PM
Jkfx400P
Sport Quads
Jul 5, 2015 10:33 PM
Sjrpp
Jul 5, 2015 09:04 PM
tweeder
Jul 5, 2015 01:57 PM
