Blaster Oil Light Probs
Old Sep 4, 2000 | 04:19 PM
01blaster's Avatar
I have a 01 blaster and sometimes when i ride my oil light goes off so i turn it off i checck to see how much oil i have and i go ride again. It is fine for a little while but then it has the same problem so i was wonderin if anybody could help me out. Thanx
Old Sep 4, 2000 | 04:49 PM
HILLSVILLE69's Avatar
blasters have problems like that if yours is a 01 i would take it back, most of the time its just the wires up by the light going into the nose.
From the steering,and bouncing sometimes they will come loose/break ect. they could also be Wet,have moisture in them. i no longer have my headlight on.
Old Sep 4, 2000 | 07:09 PM
dondiesel8's Avatar
I just got an 88 blaster, there is no cover to the bulb where that light is, does it indicate low oil level in the tank, or high oil temp in the tranny?? just so I know. btw, it has never come on, I assume it doesn't work
Old Sep 4, 2000 | 10:18 PM
99fasterblasters's Avatar
The light shows when your inj. tank is low on oil!
Old Sep 6, 2000 | 01:37 PM
QuadtroSporto's Avatar
If your light sometimes goes off when you ride, then that means that it is normally on and that means big trouble! It should only come on for a few seconds when you start it, and also come on when you are low on oil! If the resevoir is full and the light won't go off then take it back, or just buy a block off kit!
Old Sep 8, 2000 | 05:53 PM
just check the wires, and the spark plug if its white or close to it u better not kick the thing,get a block off if its the injector.
Old Sep 10, 2000 | 10:10 PM
roadkill's Avatar
I've noticed, that when the oil rez is 2/3 full or lower that the light has a tendeency to come on when the riding gets hard.
Solution, top off the oil rez whenever I go ride. No fear of running dry, and if the ligh comes on, I'll know there's a serious prob.
Old Sep 10, 2000 | 10:50 PM
99RCRTrailblazer's Avatar
I filled it up to the top and no more probs it only comes on when i crank it so its runnin fine now. Thanx
Old Sep 10, 2000 | 10:54 PM
01blaster's Avatar
Sorry i was on the wrong name my friend was just over here and we were writin on his name.
fordfaithful21
Dec 7, 2015 05:52 PM
MooseHenden
Family ATVing Photos
Sep 20, 2015 04:14 PM
nastyblaster100
Sep 13, 2015 01:19 PM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
