rancher 4x4 choke
Old Nov 16, 2004 | 09:36 PM
nascar's Avatar
Default rancher 4x4 choke
Hi got a new rancher 4x4 not to shure how to use the choke to you pull it out and leave it their or do you pull it out then push it back in right away mine allways stalls if i push it in right away any help will be appreated thanks
Old Nov 16, 2004 | 10:10 PM
TRIPLELSTROKER's Avatar
Heh Nascar, usually a choke is only needed when the vehicle is cold. When cold, you will pull the choke all the way out and hit your starter button. Once it cranks slowly push it in about half way and leave it there for a couple of minutes untill the engine warms up. Then push it all the way in and start riding..Enjoy your new atv and be careful. Your owners manual should tell you the approximate temperatures you will need to use your choke. I know around her in south carolina, if the days are over 60 degrees f. you dont even need a choke..
Old Nov 16, 2004 | 10:14 PM
nascar's Avatar
thanks i live in michigan and it is getting cold here. i will try the choke tommorow
Old Nov 16, 2004 | 10:24 PM
Another thing about the choke that you need to know since you live in Michigan, when sitting on the bike you can look at the carb bowl on your left side, shifter side, on the bowl you will notice a primer **** sticking out at you about an inch or so..In real cold weather like around 25 degrees or so, if the bike doesnt start with the choke all the way out after a couple of tries, pump the primer button 3 or 4 times and then try starting it.. The primer is designed for the colder climates like you live in and will make a tremendous difference for you starting the atv when super cold. If you didnt get an owners manual with the atv, it would be well worth it to have your dealer get you one..it has lots of information for operating and taking care of your machine.
Old Nov 16, 2004 | 10:38 PM
nascar's Avatar
thanks for all the info i appreate it
Johnny Mac
Aug 15, 2019 03:13 PM
wrencher82
Sep 30, 2015 04:27 AM
2many2ride
Sep 27, 2015 04:35 AM
Clint Russell
Sep 25, 2015 03:20 PM
wrencher82
Sep 24, 2015 03:39 PM
