Predator Rear shock ?????
Old Nov 21, 2004 | 08:50 PM
PaulPud's Avatar
Default Predator Rear shock ?????
Anyone have any problems with the line blowing up from the resevior. my friends earnhardt blew the line up twice in one month. the dealership fixed it for nothing but its becoming a pain in the ***.
Old Nov 21, 2004 | 09:44 PM
QuadAddiction's Avatar
First of all, Welcome to the forums!
Second of all, none of the preds i know had that problem so i can't help you...
Old Nov 22, 2004 | 01:49 AM
PaulPud's Avatar
i know hes 250lbs, and when he jumps he has bottomed out the suspension a couple times. he leaves the compression on 8. should he maybe tighten the spring down and loosen the compression.
Old Nov 22, 2004 | 03:48 AM
Revlimiterdude's Avatar
At 250 he really needs to get a new rear spring put on at least. Not sure how good he is but the best way to go about it is send the entire shock in and get it redone. Get the correct spring put on it and then have it valved accordingly. We send our stuff to AfterShocks in CA, he does AWESOME work and is very reasonable. If you want his details let me know!
-Shane
;o)
Old Nov 22, 2004 | 10:19 AM
Flynbryan's Avatar
Yes, I've heard of it before. Tell your friend/or his mechanic to take a look at the line as someone compresses the rear end for them. The guys that have had this problem found that the chain was coming into contact with the braided line, and rubbing it till it wore through. When they remount the rezzie they need to take the time to make sure that nothing is going to rub it. Good luck, hope this helps.
Old Nov 22, 2004 | 05:49 PM
PaulPud's Avatar
it has to be the chain, the dealership said it looks like he caught a branch or something. ill tell him to check that when he gets home tonight, and im going to go check it on mine right now. im only 190 so i havent had a problem yet.
Old Nov 22, 2004 | 07:15 PM
Heapster's Avatar
I bet its the rear chain wearing the brake line too............while I'm not up to 250 pounds, I'm pretty close and I've never had a problem with my rear spring bottoming that hard............definately set the spring preload for about 2.5-3" of sag when the rider is on the machine. That stiff a compress setting on 8 must make it a bucking ride over woops and such!
Old Nov 22, 2004 | 11:32 PM
Crapo85's Avatar
Mine did it twice and this last time I had a longer line put on it so could route it different!!
Old Dec 17, 2004 | 04:16 PM
Bugsy's Avatar
I had the same problem, I'm about 220 and ride with the rear rezzie set on 3 or 4 (to save my spine in the woops) The line rubs on the small slap gaurd wheel..Not sure what the real name is. Simple fix would be a zip tie. Lucky for me Polaris took care of the fix for me.
By the way Hi, this is my first post....I do most of my posting on Glamisdunes.com and Predatorowners.com
Bratman2
Aug 6, 2022 01:42 AM
STLyamwar
Jul 25, 2020 04:44 AM
07Redrider400
Jul 25, 2015 05:31 PM
1966F100
Jul 12, 2015 03:08 AM
cSchwartz
Jul 9, 2015 02:40 PM
