overload front spring for snow plow application!!!
Old Nov 28, 2004 | 12:20 AM
MALAHATMAGUIVER's Avatar
Default overload front spring for snow plow application!!!
i was concerned with how the front end was overloaded with the plow lifted up.checked in with my local spring shop and bounced my idea off the boys.he ask, how much extra weight?so i guessed at 150 lbs.so i measured from ball joint to ball joint,28 inches with a 3 inch arch.this is proto type #1. so i welded a 5/8 NC nuts into the lower control arm ,flush with the bottom of the a-arms out at the ball joint. notched both ends of the spring so it could slide when loaded. so now before you put the plow on you place the spring into place and hand tight a couple 5/8NC x 1 1/5 inch bolt up through the slot in the ends of the spring into the nuts( that i welded into the lower control arms) hook up plow and instant spring load that can handle the extra weight. now this is my first attempt, i think a little rubber bumper bolted through the center of the spring will help centre the spring . i don't have pictures,yet.if anybody thinks that damage could occur to any parts feel free to post concerns...thanks
Old Nov 28, 2004 | 10:58 AM
mastrblastr's Avatar
I put a set of front spring stiffeners out of Royal Distributing on my 650. About $15 for the set and takes 2 minutes to put on. They work really well.
Old Dec 14, 2004 | 09:30 AM
jpsdiving's Avatar
MB, you have some really nice ideas, welcome to the community.
Old Dec 14, 2004 | 11:46 AM
DANSAM's Avatar
[img]i/expressions/face-icon-small-smile.gif[/img] SWISHER WAS MUCH MORE SIMPLE, AND THE BRUTE CAN STILL LIFT THE FRONT!
Old Dec 14, 2004 | 09:47 PM
Thanks Jps. Thats half the fun of owning a toy. You get to tweak it out and build things for it to make it even more fun!!
Old Dec 14, 2004 | 09:52 PM
jpsdiving's Avatar
Keep us posted with any new ideas.
baysport
Jul 23, 2015 11:37 AM
Gtsordo
Jul 13, 2015 10:38 PM
DOC HOLIDAY
Jul 9, 2015 01:09 PM
cornermike
Jul 8, 2015 11:44 PM
Mphillips
Jul 2, 2015 07:20 PM
