500 sportsman won't start...need help please
Old Nov 28, 2004 | 06:46 PM
AzzKikr's Avatar
Default 500 sportsman won't start...need help please
My 2004 Sportsman 500 HO will not start with the ignition key. I have a battery charger/maintainer on and it says battery is charged. When I turn the key it just clicks. It will start when I pull start. Any suggestions on what the problem is and how I go about fixing it?? Thanks
Old Nov 28, 2004 | 06:57 PM
NascarFan's Avatar
I would "short" around the starter solanoid with a jumper and see if the starter turns. If the starter turns then the solanoid is bad. If not, the starter is likely bad, if your voltage to this point is good.
Old Nov 28, 2004 | 07:46 PM
hondabuster's Avatar
Check the cable connections for corosion, if you have a voltmeter, hook it up, and read the voltage when you hit the starter. If its dropping...get the battery load tested.
Jmuddin284
Jan 19, 2026 07:16 AM
chingchangchong
Aug 7, 2022 11:36 AM
slowgsxr97
Sep 8, 2015 07:33 PM
Pahuntman
Sep 5, 2015 11:07 AM
cdstang
Aug 31, 2015 07:52 AM
