Problems with 03 pred
Old Nov 29, 2004 | 01:30 PM
Randalscandal's Avatar
Default Problems with 03 pred
Well my pred is acting wierd it starts up fine but when you give it gas it sputters and barely goes. What could be the problem???
Old Nov 29, 2004 | 02:17 PM
omahapredator's Avatar
definately carb problem....air screw? pilot jet?
Old Nov 29, 2004 | 03:00 PM
PredFan's Avatar
Could be an airleak. check to make sure the airbox lid is seated properly, and the air tube is mounted to the carb and airbox lid properly.
Old Nov 29, 2004 | 03:21 PM
good call predfan
Old Dec 1, 2004 | 02:11 PM
atvvet's Avatar
I had a similiar problem with my 03 Predator. It turned out to be a small hole in carb diaphram, causing a vacuum leak in the carb. Replacing the part was easy and solved the problem in 5 minutes.
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
