engine brake failure
Old Dec 1, 2004 | 04:47 PM
praire360's Avatar
Default engine brake failure
[img]i/expressions/face-icon-small-disgusted.gif[/img]i have a 03 praire 360. the engine brake had ascreeching noise in it when it engaged and disengaged. so i took it off ,and took it apart to see if i could find the problem and found nothing. so iput it back on and turned the key it cut in and staarted to move then the 4wd light started to blink. i went for a ride the light still kept blinking and the brake still wouldnt work. so what did i do wrong? it was working before i removed it now when i installed it back on it wont work at all. oh by the way the 4wd drive actuator still works. and beforewhen i ride before the brake gave out altogether the 4wd light would come blinking on and the brake wouldnt work. i would have to shut off the bike to get the light to stop and get the brake working again. when i shut the key off and turn it back on agin the brake actuator woulkd cut in for a breif second the everything would be ok again . what could be the problem? please someone respond it is very disgruntling [img]i/expressions/face-icon-small-confused.gif[/img]
Old Dec 2, 2004 | 09:56 AM
Nightryder888's Avatar
mine was screeching like you described and i had to have it replaced because it was sticking.
Old Dec 2, 2004 | 10:10 AM
praire360's Avatar
my actuator works when hoohed up direct to a battery. but when hooked to the bike it will not work, i cheked all fuses and wire connections and everything seems to be ok. thanks for input though. anyone else?[img]i/expressions/face-icon-small-smile.gif[/img]
Old Dec 2, 2004 | 04:31 PM
Uinthas's Avatar
inside the belt cover you wil see the metal guide the actuator sits in (guess that's what you'd call it) well as that actuator turns it will travel up & down that metal guide. The actuator needs to be to the top of it's travel in order for it to work correctly you can do this by a direct connection from your battery until it gets to the top of it's travel, if it's out of position tit wont work...
Johnclay
Utility ATVs
Jul 19, 2015 10:00 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
clsharky
Jul 13, 2015 02:07 PM
timster911
Jul 13, 2015 01:57 PM
MNatv89
Jul 7, 2015 11:36 AM
