Battery life
Old Dec 6, 2004 | 07:02 PM
700cc's Avatar
Default Battery life
I have a 2004 Prairie 700 purchased new in November 2003. I was riding regularly but, with the wet Winter weather, it hasn't been cranked in a month. I tried to crank it Saturday, and the battery was too weak to do the job. I pull-started it, and left it running for an hour. On Sunday, same problem. Do I need a new battery? Or to keep the current one on a battery tender when it won't be cranked for extended periods?
Old Dec 6, 2004 | 07:36 PM
MikeRhyne's Avatar
Your battery should be ok - it just needs a good charge. Idling for an hour may not have been enough to charge it back up. If you have a charger pull it out and give it a full charge and let it sit out overnight. If it cranks the next day then you are most likley ok if it doesn't crank then its not holding a charge. An auto parts store can do a better test by placing a load on it and seeing how much charge it held.
Old Dec 7, 2004 | 10:52 AM
400PrarieXLT's Avatar
I got 3 months out of my first battery, and 1 month out of the one after that, and now I have about 1.5 years on the current bad battery. I havent had good battery luck. Also, if you were trying to charge the battery with it running at idle, it probably wasnt happening, I found you have to ride with good rpm's to charge the battery from the machine. Im getting a solar battery tender for when mine sits a long time.
Old Dec 10, 2004 | 02:08 AM
KVRMUDDRUNNER's Avatar
Yea, takes some major RPM's to charge any battery. Usually like 3 grand or somethin? not sure. idling won't charge up a battery. If you do charge it fully and it still goes down, i'd say you got a charging coil prob. hook a volt meter up to the battery and rev the motor up. If its got 14Volts and climbing, its charging. Then i would say you got a bad battery. Good luck!
Old Dec 10, 2004 | 05:18 AM
Customfabandweld's Avatar
Sometimes I go a month without starting my quad. The battery is 11 months old, and shows no sign of slowing down.
Old Dec 12, 2004 | 02:01 PM
kawakasi's Avatar
Bought my unit March of 02...Had to replace the battery July of 02 {warranty}
Been fine ever since
Maybe Kaw got a batch of lame batteries?
Kasi
Reactant
Mar 30, 2022 02:08 AM
Hunter100us
Oct 7, 2015 11:46 PM
scram5050
Sep 3, 2015 05:06 PM
cody500ho
14
Aug 14, 2015 05:03 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
