400EX Choke Removal
Old Dec 7, 2004 | 02:35 PM
Stoic's Avatar
Default 400EX Choke Removal
Has anyone removed their choke from the stock carb on a 400EX? What is the performance advantages and disadvantages to removing the choke? Does the stock pilot jet have to be replaced with a 42.
thanks
Old Dec 7, 2004 | 09:53 PM
Badbiker's Avatar
I've got an o3 wich is only about 7 months old and I seriously doubt I'd even get mine started without a choke. It's very cold blooded.
Old Dec 8, 2004 | 11:18 AM
warmdye's Avatar
ya, theres NO WAY mine will start without choke when its cold.
Old Dec 8, 2004 | 01:52 PM
Wes350x's Avatar
Thats what the bigger pilot jet is for. I have read this choke removal thing on exriders but have never heard of anyone doing it.
Old Dec 8, 2004 | 03:34 PM
warmdye's Avatar
ic
Old Dec 9, 2004 | 12:00 AM
TractorPacker's Avatar
Do you have a balloon?
You can get away with it if you raise the compression. I have an FCR carb on my 400, I just pump it while starting and it fires right up. It doesn't come with a choke. If you have looked in the carb you could see the advantage to removing the choke. It must be 15 to 20% blockage of the venturi.
Old Dec 9, 2004 | 02:10 PM
Stoic's Avatar
I have a Trinity 440 kit which is 12.5:1 on the compression. Has anyone on the forum ridden a 400EX with the choke removed?
thanks
Old Dec 9, 2004 | 03:50 PM
cals400ex's Avatar
i have. it was a waste in my opinion so i put it back on. it was harder to start too. others claim it was easier but i don't see how. yes, going up on the pilot jet does help. i have tried a 40, 42,and 45. all seem to work but you just need to make minor changes to the fuel screw position. mine still wouldn't start in winter without the choke. pumping the gas a few times does help though.
Old Dec 9, 2004 | 10:37 PM
86LT250RFatty's Avatar
I removed the Choke on my LT250R, and it made a noticable Increase in power, expecially in off-idle and when its screeming.
XxS0ccerstarxX
Oct 18, 2021 10:03 PM
Espo720
Technical and How-To Articles
Aug 19, 2015 02:44 PM
house1
Aug 9, 2015 10:49 PM
XxS0ccerstarxX
Aug 7, 2015 06:18 PM
ghost civic
Jul 27, 2015 03:15 AM
