How deep is too deep?
Old Dec 9, 2004 | 06:43 PM
700cc's Avatar
Default How deep is too deep?
Where is the air intake located on the Prairie 700? If I traverse water up to the racks, will this be a problem? What about the belt housing? Is it waterproof? If not, how do you drain it if you go too deep?
Old Dec 9, 2004 | 07:01 PM
tuffEnuf's Avatar
Your clutch/cvt air exhaust is rear & below the back bottom part of your airfilter assembly. If you had it up to your racks you probably got water in your clutch. Remove all your bolts from CVT cover, drain, dry & clean your components.
The CVT air inlet is just at the bottom of your of your handlebar plastic, opposite your aircleaner intake[img]i/expressions/face-icon-small-happy.gif[/img]
TuffENuff
Old Dec 9, 2004 | 08:41 PM
bushpusher's Avatar
water up to the racks is no problem as long as you keep moving. water won't enter the cvt exhaust unless you are stopped. the bow wave will keep the water out of the intake as it is up high by the handle bar and water doesn't have direct access to it. to get water out of the cvt just rev up the engine in neutral for a while to blow the water out and dry off the belt. I have never had to remove my cover to dry it out yet.
Old Dec 10, 2004 | 01:08 AM
KVRMUDDRUNNER's Avatar
I thought there was a little rubber plug at the bottom of the CVT cover? I think my V-Force has one. My buddy goes through water all the time with his P700 and never has a prob. Sometimes his atv is floating, hahaha. Thats a sight right there!
Old Dec 10, 2004 | 03:01 AM
wildrides's Avatar
somrtimes when i fly thru 15 " to "24" puddles my belt will get wet so i rev it up to dry it out
Old Dec 13, 2004 | 08:59 AM
turbojosh's Avatar
Just don't flip your atv over in water. Not good. But you can go through some deep stuff.
If you do flood it out. You will need to change everything like plugs,oils,diff-fluids,gas.
Customer Service #1
May 15, 2020 08:46 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
switzomatic
Aug 24, 2015 12:57 PM
