400ex starting problem
Old Dec 11, 2004 | 06:15 PM
Xtremerider698's Avatar
Default 400ex starting problem
hey i have a 02 400ex i've been haveing a prob. starting it i push the electric start button and nothing happens (no noise either) i thought it might be the bat. so i got a new one nothing still [img]i/expressions/face-icon-small-mad.gif[/img]
Old Dec 11, 2004 | 06:22 PM
TractorPacker's Avatar
Do you have a balloon?
Sorry for the obvious, but you did check the fuse, right?
Old Dec 11, 2004 | 06:24 PM
ubertrailblazer01's Avatar
make sure its in neutral
and check the killswitch, make sure its lined up in the middle
Old Dec 11, 2004 | 06:37 PM
well to tell u the truth i didnt check the fuse i had no clue there was one........were is it ? thanks
Old Dec 11, 2004 | 07:04 PM
Under the seat by the air box. There is a little plastic cover with a fuse and a spare if no one took it yet.
Old Dec 11, 2004 | 07:31 PM
thanks i am gonna have to try it ... i always wondered wut that was thanks again[img]i/expressions/face-icon-small-smile.gif[/img]
Old Dec 11, 2004 | 07:41 PM
300exStroked's Avatar
if all else fails check your grounds..
Old Dec 11, 2004 | 10:37 PM
URCRAZY's Avatar
Try your starter solenoid, jump it with a screwdriver between the two post, if it starts then it could be your starter button, or the solenoid, of course if your grounds, and fuse is ok.
Old Dec 12, 2004 | 12:09 PM
SpeedDemon13's Avatar
if all that doesnt work them just pull in your clutch, every once and a while it will do that on mine, it just wont make ne noise and then pull in the clutch and starts right up
DTroyer01
Jul 3, 2015 07:34 AM
generalpops
Jun 5, 2015 08:23 PM
garyt1975
Jun 5, 2015 08:53 AM
generalpops
Jun 3, 2015 08:25 PM
1000gade
May 27, 2015 12:37 PM
