GRIZZLY-water in the oil after every ride
Old Sep 9, 2000 | 10:13 PM
km74's Avatar
I have a 2001 grizzly. It has 140 miles on it. Every time I have went through deep water you can see water in the oil through the sight glass. I checked the breather hose and it is secure. Where else could the water be coming from? I have changed the oil after both times in the water. It didn't quit or bog down when in the water. Any suggestions? Thanks
Old Sep 9, 2000 | 10:38 PM
IndyDave's Avatar
Dip stick tube maybe ?
Old Sep 9, 2000 | 10:45 PM
km74's Avatar
There is no dipstick on this model. Only a site glass to show you the level of the oil
Old Sep 9, 2000 | 10:51 PM
IndyDave's Avatar
Oh...sorry. Better learn something about Yamahas before I give advice.
Dave
Old Sep 10, 2000 | 11:26 AM
wolfy's Avatar
what about the oil fill then
Old Sep 10, 2000 | 12:41 PM
km74's Avatar
Yes the oil fill cap is on and every other obvious thing has been checked but thanks for the reply.
Old Sep 10, 2000 | 01:13 PM
01Grizzly's Avatar
Wish I could offer you some advice about your problem, but I can't. I to have a 2001 Griz. Put it through alot of water from time to time and I have never had that happen to me. Check out the oil filter cover. If its not tight enough or if the rubber seal is missing or damaged, water might get in there. But you would also see some oil leakage. Or maybe the oil cooler has a small hole in it? Or one of the tubes feeding the oil cooler. How do you let water in without letting the oil leak out. As long as your filler cap is on. If I were you I'd do a real close inspection of the engine and see if there is anywhere you might be leaking alittle oil. If you find some, then that could be the culprit.I don't know!?
Nondem
Feb 22, 2020 12:20 PM
HondaR24
Jul 16, 2015 10:45 AM
honda71
Jul 12, 2015 05:56 AM
Edgeslade
Where to Ride
Jul 10, 2015 05:08 PM
honda71
Jul 8, 2015 02:13 AM
