Yamoto 150 Air filter replacement
Old Dec 17, 2004 | 02:10 PM
Waylonrules's Avatar
Default Yamoto 150 Air filter replacement
Hello, I have seen in the postings that people are replacing their Yamoto 150 air filters with a K&N filter. Is it a direct fit and if it is what is the K&N part number? Thanks for your help!
Old Dec 17, 2004 | 05:13 PM
Raptorlegs's Avatar
T Rex Rider
What irritates me is!
Those 6-packs work pretty good.
If it's the round filter. Measure your opening and size of filter and go to K&N's website. They have a list of filters you can match to pretty easy.
Old Dec 19, 2004 | 10:11 PM
Will67's Avatar
K&N filter #R-1100 is what I've seen recommended. The pre-charger filter wrap is #22-8048PK. I just installed both on my machine. You have to completely remove the airbox to install.
Old Dec 24, 2004 | 12:39 AM
yamoto150owner's Avatar
After installing th new filter , does the machine have a performance gain?
Old Dec 24, 2004 | 09:47 AM
Will67's Avatar
I definately noticed a difference in performance. The machine certainly breathes better and is more responsive when you hit the throttle. I ended up at exactly 1 turn out with the air/fuel mixture screw after installation of the K&N.
Old Dec 24, 2004 | 07:33 PM
where is the air fuel mixture screw???
Old Aug 8, 2005 | 11:59 AM
paulmurphy777's Avatar
do you think that this K&N filter #R-1100 will work for the yamoto 200cc, i thought they had the same carb, but other people say different. any info appreciated!
Old Aug 8, 2005 | 12:22 PM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Welcome to the forum paulmurphy777, You will need to measure the back of the carb to determine what diameter it is.
Old Aug 9, 2005 | 05:32 AM
ah, found the universal filter page on k & n, shouldn't be a problem. thanks for the advice!
lightninboy
May 16, 2021 09:52 PM
bpegram84
Jul 22, 2015 08:15 AM
bpegram84
Jul 22, 2015 08:12 AM
Aitch
Jul 21, 2015 09:40 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
