no tension on clutch lifter arm?
Old Dec 19, 2004 | 01:47 PM
400exky1e's Avatar
Default no tension on clutch lifter arm?
i removed my clutch cable the other day to clean it and this is now my problem: ever since i did that there is no tension on the lifter arm that goes into the transmission, i replaced the lifter arm spring with no results. for example i can pull the clutch in with my pinky, and it doesnt go back in place when u let go, the arm is not pulling back like it should and it also seems like it doesnt come as far forward as it used to. any help would be greatly appreciated
thanks,
kyle
Old Dec 20, 2004 | 11:55 AM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
is the cable hooked back up?
there will be slack once the clutch is engaged (the lever will feel loose)
hook the cable back up and pull the lever
Old Dec 20, 2004 | 01:28 PM
Bing's Avatar
Super Quad Patrol
you may have broken the little pin that pulls the clutch out
Old Dec 20, 2004 | 01:47 PM
400exky1e's Avatar
yeah its hooked up, and the pin is still there, but is there supposed to be tension on the pin too or is it supposed to move freely? cus it moves freely
Old Dec 21, 2004 | 02:42 PM
Bing's Avatar
Super Quad Patrol
the pin Im talking about is located in the center of the pressure plate inside the clutch cover (it pulls the pressure plate off of the clutch plates)
you wouldnt be able to see if it is broken
sounds like this is your problem
Old Dec 21, 2004 | 08:14 PM
400exky1e's Avatar
the pin ur talking about comes out of the middle and its what the lifter arm pulls and pushes right? i have that, but it moves freely about 1/2 an inch, should there be pressure on it?
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
raman8tor
Sep 20, 2015 07:35 AM
Ridgebackguy86
Sep 19, 2015 12:48 PM
