gas leaking from my drain tube how do i stop it?HELP!
Old Dec 22, 2004 | 05:33 PM
Lakotalen's Avatar
Default gas leaking from my drain tube how do i stop it?HELP!
I have a 2001 Kawasaki Lakota sport 300 and gas is like pooring out of the drain tube from the carb how do i stop it?
plz help!!
Old Dec 22, 2004 | 10:16 PM
Doctorturbo's Avatar
GOT BOOST!
If it's the bowl vent you have trash under the inlet needle valve or the float is stuck for some reason. Take the bowl off and clean the valve and check the float and make sure it is not hanging up.
Old Dec 22, 2004 | 10:17 PM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
what he said
or you left your bowl drain screw loose
Old Dec 23, 2004 | 02:49 AM
Polaridoo's Avatar
Make sure the float level is not too high either.
Old Dec 23, 2004 | 11:06 PM
Larch's Avatar
I've got a Prairie and had the exact same thing happen. Turns out the float needle and seat were gunked up. Make sure to clean both, especially the seat, real good. Use scotchbrite on the seat to get all the gunk off it. Don't just spray it with carb cleaner and blow it off.
Old Dec 24, 2004 | 12:40 AM
Lakotalen's Avatar
how do u control the float level?
Old Dec 24, 2004 | 02:20 AM
Polaridoo's Avatar
You can bend the tab (it's very thin, soft metal - brass I think) that the needle is attached to. Bend it upwards if you want to lower the amount of fuel in the bowl (so that it shuts the fuel off sooner) or bend it down to raise the level. Usually in the shop manual it shows what the float level should be... sometimes the dealer sells a special gauge / tool that helps you measure it. I have usually eye-balled it and done trial and error until it seems right.
SDR-II
Sep 29, 2015 01:06 AM
Hankey Pankey
Jul 31, 2015 05:50 PM
Hankey Pankey
Technical and How-To Articles
Jul 29, 2015 10:57 PM
skeets44
Jul 17, 2015 01:04 PM
Shifts
Jul 3, 2015 07:59 AM
