mixture ratio for 99 eton 50
Old Dec 24, 2004 | 08:05 PM
chubbysdad's Avatar
Default mixture ratio for 99 eton 50
I am giving up on the oil injector on my sons 50. What mixture does the pump give? 32/1?
Old Dec 25, 2004 | 12:07 AM
spike99's Avatar
Yes, many people start with 32:1 and further tweak their oil mixture depending upon spark plug color, and how much smoke it pumps out the tail pipe. Our unit is currently running 34:1 and in the future, I'll probably go down to 36:1. However, start with 32:1 and tweak from there. Oil brand and riding conditions do influence your oil ratio.
Old Dec 25, 2004 | 12:13 AM
chubbysdad's Avatar
thanks for responding.
Old Dec 27, 2004 | 09:51 PM
Randes's Avatar
The factory oil injector is set at 50:1
Old Feb 24, 2005 | 06:50 PM
chubbysdad's Avatar
I never got around to disconecting the oil injection. What is involved with doing that? just disconect hose from tank? Will it inject air in to carb instead? Hope I dont sound stupid asking.
Old Feb 24, 2005 | 08:59 PM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
I did it to a kawasaki 120 and a suzuki 90. I just removed the pump and made a cover plate to cover the hole. Not sure on the eton. Did you plug the line? I would think it would suck air. I run 40-1 in all my 2 strokes, torco gp7. Been using it over 20 years, never fouled a plug.
Old Feb 24, 2005 | 10:14 PM
chubbysdad's Avatar
No I didn't do it yet. I dont think it is pumping enough oil so I do mix 50:1 also. So now i am running a little rich and want to get that taken care of .
Old Feb 24, 2005 | 10:21 PM
spike99's Avatar
chubbysdad,
I sent you a PM with the Oil Injection removal instructions. Running rich??? Your factory pump may be working fine, expect the jets in your carb need to tweaked or upgraded to a different size. But if you feel removing the Oil Injection system will give you better control of your oil mixture, the details are within the PM I sent you.
Hope this helps...
Old Feb 25, 2005 | 08:51 AM
chubbysdad's Avatar
The reason I say it is rich now is because the injection is not working to its max I believe because the plug was very light.. Thats why I mixed up a little premix also and now am running both until Iget it disconnected. thanks for the info.
Honski250r
Sep 26, 2015 09:40 PM
rockinkgin
Sep 25, 2015 01:52 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Minimod
Sep 10, 2015 09:20 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
