flashing 2wd 4wd
Old Dec 26, 2004 | 01:45 PM
justin99's Avatar
Default flashing 2wd 4wd
my 02 prairie 650 is flashing 2wd 4wd, i changed the 3 fuses underneath the seat and that didnt fix the problem. what else is there to check or do. i really need to get this working, it snowed alot here.
Old Dec 26, 2004 | 03:24 PM
Gougeonit's Avatar
A quick flashing 2wd/4wd lights mean there is a problem with the 4wd actuator --- 1/2 second interval
A slow flashing 2wd/4wd lights mean there is a problem with the EBC (engine brake control) --- 1 second interval
A 2 second interval indicates both actuators are malfunctioning.
But before you get too involved in fixing the ebc or actuator... make sure all the fuses are good and have a good connection.
From my experience, this is where most problems are found, the fuse box contacts will corrode over time and give you problems.
hope this helps
speedbuff
13
Nov 11, 2020 10:16 AM
vandammages@gmail.com
Aug 20, 2020 11:50 AM
exmotocrosser
Sep 26, 2015 08:18 AM
patrick.oc123
Sep 16, 2015 03:45 AM
patrick.oc123
Sep 15, 2015 02:45 PM
