Piston/Cylinder Clearance
Old Sep 11, 2000 | 02:38 PM
dalegoldston's Avatar
How much clearance should there be between a wisco piston and the cylinder wall. The manual shows .0024-.0026. I recieved my motor from Mission and believe the wrong piston kit was sent the clearance is .020 not .002. its a Banshee motor bored .040 over stock.
Thanks
Dale
Old Sep 11, 2000 | 03:20 PM
r42176's Avatar
All of the banshee cylinders i've bored I have set up at .00225. I think they gave you the wrong piston.
Jeff
Old Sep 12, 2000 | 11:04 PM
PamFalcioni's Avatar
Dale,
Did they measure it metric, or in decimal inches? If it's metric, .020mm would be about .003" in decimal inches.
Just checking!
Old Sep 13, 2000 | 01:55 AM
RickRitter's Avatar
What size holes did they give you ?? In inches or millimeter ?
Hey Pam ,, nice to see you .. *smile* I'll call you sometime OK ??
Old Sep 13, 2000 | 02:00 AM
RickRitter's Avatar
40 over banshee holes should measure close to 2.559 inches when using Wiseco pistons . The .00225" clearance mentioned earlier is also what I think is correct .
Old Sep 13, 2000 | 02:13 PM
I had measured it with digital caliper and was talking inches. I e-mailed wiseco and recieved the info I needed they said for a stock motor the clearance should be .003" and for a modded motor, i.e. porting,cool head ect. that .0035-.004" was the proper clearance. Its a little above stock clearance due to the differance in the pistons, cast being stock and forged being wiseco. I sent Mission my cylinders and pistons they said they would make it wright. Just keeping me down a little longer is all. Thanks for the replies.
slowgsxr97
Mar 18, 2022 03:40 AM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
handyjc1
ATC 3-Wheelers
Oct 23, 2015 07:15 PM
MrTrashMan2U
1) Engine problems..
Sep 9, 2015 11:11 AM
