Fouled Plugs? What tools needed?
Old Dec 30, 2004 | 07:05 PM
Razorcat's Avatar
Default Fouled Plugs? What tools needed?
Hey everyone - My DS won't start and I'm hoping it is fouled plug(s). It started fine one day, the next it just wouldn't start. My problem is that I don't have the right tools for the job. (After moving from home I'm slowly starting my own tool collection) Can anyone tell me what I will need to take out the plugs and clean them? I assume I'll need a set of deep metric sockets, but I'd like to make sure. Thanks in advance!
Old Dec 30, 2004 | 07:44 PM
CTATV's Avatar
I dont know how they are placed on the DS but on my quadzilla i just do it with an ajustable cresent wrench. If it is recessed down in the head then yes a deep socket would be needed. as far as cleaning it I have personally found that cleaning them doesnt often get me the result i want. For the 3 bucks plus 20 cents in gas i drive down to NAPA and get a new plug and throw it in. you can try to clean yours with some carb cleaner or WD40 type solvent. remember that if you are putting a used plug back into the head dont overtighten it because the lock washer has already been crushed. just tigten it till it is firm and leave it there. if you have a torque wrench to use with your sockets thats the safest way and if you do your own engine work its a good thing to have down the road in your collection.
Old Dec 30, 2004 | 07:56 PM
DONECRASHED's Avatar
You will need to use the metric socket on your plugs. They are side by side and are pretty hard to reach. If you still have your Bomb tool kit that came with your bike located under the seat then use the plug wrench, it works just fine. You will also need to replace the plugs, not clean them. I doubt that your plugs are the problem, but you never know. So just go buy two new plugs that way you can rule out "bad plugs" on your way to fixing your bike.
Old Dec 30, 2004 | 08:06 PM
atvaddict01's Avatar
18mm deep socket
ngk dr8ea
Old Jan 2, 2005 | 01:13 PM
Razorcat's Avatar
Thanks for the replies. I'll report back the results. Keep your fingers crossed and thanks again!
Old Jan 6, 2005 | 09:21 AM
Razorcat's Avatar
Put in new plugs and she fired right up! Thanks again for the replies!
jrooker6
Ask the Editor
11
Apr 21, 2016 07:35 PM
WilliamBos
Sep 30, 2015 08:08 AM
rapple
Jun 2, 2015 01:38 PM
Wils400EX
Oct 14, 1999 04:57 PM
