Lt80 rear brake
Old Dec 31, 2004 | 02:25 AM
Voodoo52's Avatar
Default Lt80 rear brake
Ok I just installed our +2 swinger and I'm having brake issues.
When you push down on the pedal it doesnt return properly, causing the brakes to hang up. All the springs are on properly including the one on the arm for the rear brake.
Now where the mount for the cable is, on the frame, just behind the pedal, should the cable slide back and forth in that mount? mine does and to me that looks like the problem, but theres no type of adjustment there.
Please help we're suppose to go riding Sat.
Thanks
Dan
Old Dec 31, 2004 | 10:58 AM
LT80's Avatar
LT80 Expert
I go to ther hardware store and buy a "L" bracket. I then drill 2 holes on the brake lever and put the L bracket on that. I then run a spring from the skidplate to the L bracket.
This returns them great! And for like 5 bucks or less.
What ya figure the +2 length will do?
Old Dec 31, 2004 | 02:45 PM
homdaddy's Avatar
the other day i was on ebay and saw a lt for sale the guy used it for tt racing. anyways it had a disc brake on the back. has anyone done this ? is there a kit
Old Dec 31, 2004 | 05:45 PM
Voodoo52's Avatar
Hey Lt you got any pics of that setup. I'm not sure exactly where you're putting the "L" on the arm.
Also is the cable suppose to move back and forth in that 1st mounting bracket?
Old Dec 31, 2004 | 05:53 PM
LT80's Avatar
LT80 Expert
Sorry no pics.
I put the bracket right below the adjustment nut,,on that arm.
Yes the cable does move a lil on that 1st bracket,,...there is no adjustment there (as you noted) but it does move a lil I think
Old Feb 18, 2005 | 07:07 PM
chumbini's Avatar
Where did you get the plus two swinger axle? How much is it?
Old Feb 27, 2005 | 08:59 PM
chumbini's Avatar
where did you get the swing-arm extender?
STLyamwar
Jul 25, 2020 04:44 AM
greg74
Sep 10, 2019 03:03 PM
DeFox500
Aug 14, 2015 05:59 PM
Bergmann
Aug 13, 2015 03:51 PM
SixSpeed5
8
Aug 2, 2015 05:38 PM
