Where is that supposed to go???
Old Dec 31, 2004 | 06:54 PM
Backinthesaddleagain's Avatar
Default Where is that supposed to go???
2004 Sportsman 400.
Small tube coming off the bottom of the carb. It's only about 1/8" dia. max. It's connected to the bottom of the carb and runs for about 1". It then has a disc-like 'device' of some sort that is about 1/2" to 3/4" dia. and looks like a miniature frisbee except it has the tubing connetors, then the tube continues down to an area behind the engine where it just hangs and does not connect to anything.
Is this just a carb bowl drain and it's supposed to be like this???........or is this free hanging open ended tube supposed to be connected to something???
Bob
Old Dec 31, 2004 | 07:09 PM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
sounds like an overflow tube with an inline one-way valve
it is clear tubing,,,right?
Old Dec 31, 2004 | 07:40 PM
Yep.......it's clear tubing but it's connected right to the very bottom/underneath/bowl of the carb. That's why I'm thinking it's just a drain line and yeh I'm also thinking the "frisbee" is a check valve but I don't know for sure.
Thanks, Bob
Hey Bing........GO PATS!!!
Old Dec 31, 2004 | 07:41 PM
...........and Oh Yeh............My kids absolutely LOVE "The Annoying Thing"!!!
Old Dec 31, 2004 | 07:51 PM
Bing's Avatar
Super Quad Patrol
Thanks, Bob
go pats is right!!!
the overflow would be located on the bottom of the bowl,,,,,,,sounds right
there should be a screw right near where that tube hooks to the bowl,,,,,,if you unscrew it,,,,fuel should run out that tube (bowl drain screw)
Old Dec 31, 2004 | 08:58 PM
Newoldkid's Avatar
The "frisbee" is a one way valve you can test it by blowing through the tubing both ways.
Old Dec 31, 2004 | 11:11 PM
So I guess it's OK to presume that this is simply a carb bowl drain and that the end of the tube SHOULD be dangling free open ended???
Old Dec 31, 2004 | 11:19 PM
Bing's Avatar
Super Quad Patrol
exactly[img]i/expressions/face-icon-small-smile.gif[/img]
i like to make sure that it isnt draining on anything that gas would aggrevate,,,,,like a rubber grommet or something
buddieboy
Dec 9, 2016 05:50 PM
John Reed
Sep 9, 2015 03:46 AM
toonces
Sep 5, 2015 01:14 PM
Dan Newberry
Aug 30, 2015 09:42 AM
Hankey Pankey
Aug 17, 2015 05:01 PM
