Thinking about selling? whats it worth?
Heh guys
I'm thinking of selling my ds and moving to a Ktm 640 adventure. What do you think it mit be worth?? 2001 Ds-650
700cc Motor
100mm bore with fire ring for higher compression and with rwr 13to1 piston custom polished top
Falicon 88mm crank balanced,weld,etc. to the piston with roller bearings
Race head with 40mm intake and 34mm exh. shim underbucket titium retainers/10mm head bolts and studs
Web Cam Special grind .450 lift (#125+5*(10*)
Has matching intake
Full stainless mbrp
45mm Mikuini carb with a full set of jets, idle jets and two KN filters
Cometic copper gaskets
Rwr box with no rev
New clutch
New trigger coil with spare
Pro motion twist throttle
I'm sure I missed a few small things! I figure I have 8000$ in the motor as it sets.
Frame
Mainly stock (used)
Modded to clear chain for flat track style racing
No nerf bars I broke one side(step on it)
Modded front bumper
Home built .35inch alu. skid plate
Bark busters modded levers.
No head light
Suspension
Elka dual rate non-res (500$)/ road racing shocks up front lower front to 5inches of ground// I still have the stock front shocks for off-road.
Asr lower a-arms
Durablue swaybar
Lowering bracket for rear shock(stock).
Sidewinder tituim chain with many spare links and spare old chain
40, 38tit. rear sprockets, 17,16,18 front sprockets
Stainless steel brake lines front
Carbon brake pads All around
pro amor rear skid still good (used hard))
spares
Cover DS-650
two kn filters
front old shocks
Old muffler
102 mm cylinder fire ringed bored for 10mm bolts and 102 pami piston (used one year)
One cometic copper head gasket
one steel cometic base grasket
Manuals
Tritium spark plugs
Front fenders
Old ign. box good spare
Tires
1 set of bandit rears 80%
1 set of bandit fronts 90%
1 set of hoosiers rears 90% raced on Pikes peak
1 set of hoosier fronts 50%
1 set of hoosier rears 50%
1 set of old stock tires front and rear 50%
1 spare front rim
These hoosier tires run 100$ each without rims
I have rims for about 50% of these tires
This bike has been used but it is the fastest 4-stroke quad on pikes peak 2004 place 6th. I have had the bike dynoed in denver,co (6000' elavation) and it made 57hp and about 50 foot pounds of torque. The engine runs passed 10000rpm and can be a real hand full. I have been radared at over 90mph at 8000' elavation. At sea level the engine hp??
I sure I missed a few things but if need to I could go into more detail I thinking of going and putting it on ebay and selling it for about 9500$ ??
what do you guys think???
PM me or email me I have some pictures
9011a@mtaonline.net
700cc Motor
Has matching intake
Full stainless mbrp
Rwr box with no rev
New clutch
Frame
Mainly stock (used)
Modded front bumper
No head light
Suspension
Asr lower a-arms
Durablue swaybar
spares
Cover DS-650
two kn filters
front old shocks
Old muffler
Manuals
Tritium spark plugs
Front fenders
Tires
1 spare front rim
9011a@mtaonline.net
I'ld sell some of the stuff separate.
The 102mm piston and jug should be worth about $500
Tires - especially the Hosiers should find a home
etc.
If you could sell some of the extras for $1000 then get $6,000 for the bike that would probably be what I would expect. . . Thoughts?
Any reason you couldn't put the 102mm bore on? Would the Pami piston work? Could you use a thicker head gasket, base gasket, or take some off the top of the piston?
Now just to find someone willing to spend $6k on a used quad. . .
etc.
You will do better parting it out..There is a slim chance you will find somebody that has that kind of cash to throw at a used bike.. A quick rule of thumb on a used modded bike is 50% of what you have in it..I know it is a sad but true figure. Look for some free sites to put it on, and see what kind of luck you get. I would not put it on ebay as it is because I think you will not get what you want, and it will cost you $$ just to list it. ( parts do good on ebay though) Good luck
