Spring spacer..700 efi.. and 26 inch tires
Old Jan 2, 2005 | 09:09 PM
astro's Avatar
Default Spring spacer..700 efi.. and 26 inch tires
I need new tires I want to get taller tires 26"...
I have searched on three forums and I think i have decided that spring spacers are the best and cheapest way for me to ride on 26" tall tires on the front of my 700 efi. Where can i get these spacers I have seen all different types from pipe to some sort of clamp to polaris spacers. Only the polaris spacers can i find.. What are the best type to use and is 2" spacer the way to go? If so where can i get these I read the polaris spacers are not too good, no reason why just what i read. Any help would be great guys.
Old Jan 2, 2005 | 09:53 PM
GE4x4's Avatar
You should be able to run 26" tires without the spacers.
Old Jan 2, 2005 | 10:57 PM
astro's Avatar
hmm... it seems a few can, but most cant... they say that 26" tall tires even if they are still 9" wide in front will rub the tie rod with stock rims... thats what i have read...
Old Jan 4, 2005 | 09:50 AM
JAMIEZ71's Avatar
I don't know why you think you need spring spacers to run 26" tires. You may have to put wheel spacers on the front tires if you run a tire too wide on the stock rims for they will rub the tie rod ends. To keep from putting wheel spacers on it you can sometimes flip the tie rod ends to the bottom of the mount and solve that problem. Spring spacers just raise the front to give you fender clearance.
Old Jan 6, 2005 | 05:20 PM
AnywhereTom's Avatar
Astro,
If you want even cheaper use a couple of hockey pucks instead of the steel spacers,just drill a aprox. 2" hole in them to fit over the shock, I put them under my front springs of my 04.5 700EFI and my front tire don't rub the fenders at all any more, unless I hit something really hard. I run mud-lites 26x12x10 on the front and 26x12x12 rear. You do have to put the wheel spacers in if you run any thing wider than an 8 inch tire on the fron though.
Also I have noticed an improvement in steering and handling around corners, the front end doesn't dive when your given'er hard in the corners.
You dont get anymore clearance by doing this ,but you definetly stiffen up the front end.
Old Feb 8, 2005 | 11:39 PM
silverbullet2005's Avatar
do yo have any pics of what your describing?
Old Feb 8, 2005 | 11:52 PM
mistertinker's Avatar
superior suspension parts
scroll down
Old Feb 9, 2005 | 12:14 AM
elkbow's Avatar
you don't need spring spacers, you need wheel spacers or offset wheels to run the 26's....or you can sell it and buy a 2005 and run up to 27's with no contact, just as long as they are 9's....not sure if you can find 28's with a 9 width, so thats why i didn't say 28's....
i've heard of people putting the 27x9-12 on their '04 machines without them hitting....need to do a search
Old Feb 9, 2005 | 12:30 AM
moosehunter's Avatar
Hi Astro...
You're going to get about a dozen or so answers to this question.... Some right, some not so right. Why not go straight to the source....
I see you're in Texas, give these guys a call...
Bert's Dirt Works
18916 I-45 North
Spring, Texas 77373
Local# (281)288-5753
Toll Free# (866)823-DIRT
I've done business with these guys a bunch of times and they really know their stuff. They specialize in ATV lifts, spacers, wheels, tires..... you name it... If they don't know the answer, it hasn't been done yet. Give the guys at Bert's a call. They won't steer you wrong.
Polaris5
Aug 29, 2015 09:11 PM
Bergmann
Aug 13, 2015 03:51 PM
chuck1177
Aug 11, 2015 03:22 PM
coolguy420
Jul 10, 2015 01:17 AM
Mphillips
Jul 2, 2015 07:20 PM
